Starting problem
Old Oct 31, 2009 | 10:53 PM
marcusa's Avatar
Default Starting problem
I have a 93 cbr 900 that doesnt want to turn over in the cold. I live in LA, so it starts fine when its warm and sunny out, but when I try and turn it on in the morning when I go to school, its like 50 or 60 degrees out, I always have to push start the bike. It will turn over a few times and then act like the battery is dead. The battery is only a couple months old. I was thinking maybe changing the spark plugs, or maybe my rectifier is going out. Any ideas would be greatly appreciated since just replacing parts can get expensive quickly.
Old Nov 1, 2009 | 02:04 PM
dsrdr's Avatar
just cause the battery's only a couple months old doesn't mean it's not bad already, that's what pro-rated warranties are for. what kind of battery is it? First thing I would do is take the seat off and test the voltage between battery terminals with the bike running at 5k rpm, shuold be around 14v, if that checks out, then take your battery in to an auto parts store to get tested. Batteries are weakest when cold so symptoms sound like the battery. Does the bike sit for long periods of time? If it sits for more than 2 weeks it should be on a battery tender
Old Nov 6, 2009 | 10:02 PM
marcusa's Avatar
Thanks, it did end up to be the battery. I'm glad I double checked that before putting in other expensive parts.
Old Nov 26, 2009 | 01:34 AM
sempul's Avatar
so did u mean louisana or los angelas? i have a 97 CBR900 in the hammond area if u wanna get together shoot me a PM.
dirtyhall
Apr 15, 2011 08:41 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
