Speedo
Old Mar 22, 2021 | 07:59 AM
Scotty601's Avatar
Default Speedo
Hi can anyone HELP.
the speedo is not working on my 1998 cbr 900 .
ive put a new speed sensor on it tried different set of clocks and even put a new wiring loom on and still not working I’m losing the will here .
Old Mar 22, 2021 | 09:57 AM
Have you performed this procedure ?
Old Mar 22, 2021 | 10:49 AM
Scotty601's Avatar
Default Speedo
I have 4.70v with the ignition on or off .
When rotating the wheel it’s 2.40 v .
Old Mar 22, 2021 | 11:48 AM
I would check to ensure that your meter is connected to the right pins on the connector. It should not be possible to have 4.7v at the Pink/Green wire with the ignition in the OFF position. The speed sensor has 3 wires. Black/Brown is supply, Green/Brown is frame ground, and Ping/Green is the signal output from that sensor. If the key/ignition switch is in the off position, then there is no power to any of the fuses, one of which provides power to the speed sensor. Also, you should rotate the wheel really slowly in order to see the change from 5v to 0v.
Old Mar 22, 2021 | 01:15 PM
Scotty601's Avatar
Default Speedo
Thanks for that I will have another check tomorrow and make sure I have the correct wires.
Old Mar 22, 2021 | 02:48 PM
chris0986's Avatar
If you have an gear indicator I would check the connectors of the speedsensor to the ECU.
The gearindicator I have, has crappy connectors. With some attention and some WD40 the connectors mine started working again.
Old Mar 24, 2021 | 01:29 PM
Scotty601's Avatar
Default Speedo
  • I definitely have 4.7v in the pink/green wire with the ignition on or off I’ve checked it a dozen times and even check it at the sensor connection and definitely 4.7v there.
  • im well puzzled
Old Mar 24, 2021 | 02:12 PM
Do you have the 900RR manual?
Old Mar 24, 2021 | 02:23 PM
Scotty601's Avatar
yeah I do it’s not giving me clues though I’ve checked the ignition and the rectifier.
there is no power through the pink/green wire when the clocks are disconnected.
ive tried 3 lots of clocks and the same thing.
Old Mar 24, 2021 | 04:15 PM
DM sent.
Scotty601
Feb 21, 2021 06:34 PM
Fearless4x4
Oct 22, 2009 05:05 PM
roadrash789
Aug 28, 2009 10:53 PM
stoneguy1037
Oct 8, 2008 03:50 PM
tiger600
Jul 27, 2008 03:37 PM
