Speedo
Old Feb 17, 2021 | 08:54 AM
Scotty601's Avatar
Default Speedo
Speedo
hi my speedo is not working I’ve tried the sensor and different clocks.
there is 12 v going to the sensor and 5 v at the clock.
the wiring has been checked and all connections cleared.
I would appreciate some help with this as I’m stuck with it .
thanks Scotty
Old Feb 19, 2021 | 08:10 AM
To start with, how about year and model ?
Old Feb 19, 2021 | 10:17 AM
Scotty601's Avatar
Default Speedo
it’s a 1998 900 RR sensor on the sprocket cover
Old Feb 19, 2021 | 01:32 PM
OK Scotty601,
You say that you have 12v at the sensor and 5v at the clock. Can you describe in as much detail (reasonably) as you can on how you are taking that measurement?
On the back of the combination meter (your gauge cluster), when measuring from the Black/Red wire and the Green/Black wire you should see a fluctuation from 0v dc to 5v dc while you are rotating the rear wheel (with it off the ground naturally).
Regards,
Old Feb 21, 2021 | 06:29 AM
Scotty601's Avatar
Default Speedo
Hi sorry for the delay I’ve been working.
it dose go from 0v dc to 5v dc when turning the rear wheel.
Old Feb 21, 2021 | 06:34 PM
It sounds like you've pretty much eliminated any possible issue with the speed sensor. May need to start looking at ebay.
https://www.ebay.com/itm/98-99-Honda...4AAOSwGKJf49dx
Fearless4x4
Oct 22, 2009 05:05 PM
stoneguy1037
Oct 8, 2008 03:50 PM
tiger600
Jul 27, 2008 03:37 PM
Miner
Apr 18, 2005 09:52 AM
