Specs
Old Oct 30, 2009 | 03:34 PM
scutfargas's Avatar
December 2011 ROTM
Default Specs
I was thinking it would be cool to have a sticky with specs on the 900RR from year to year. Kind of like a reference point. Is this something that would be helpful for everyone?
We could make each reply a new year. Sort of like this......
Old Oct 30, 2009 | 03:58 PM
scutfargas's Avatar
December 2011 ROTM
Default 1993
List Price: $8299
Liquid cooled four-stroke inline Four
Bore x Stroke: 70.0 x 58.0 mm
Displacement: 863cc
Compression Ratio: 11.0:1
Valve adjustment: 16,000 mi.
Carburetion: (4) 38mm Keihin
Battery: 12v, 8ah
Weight:
Tank empty: 432lb.
Tank full: 455lb.
Fuel Capacity: 4.9 gal.
Wheelbase: 55.0 in.
Rake/trail: 24.0/3.5in.
Seat height: 31.0in.
Ground clearance: 5.2in.
GVWR: 807lb.
Load capacity(tank full): 346lb.
Front suspension:
Manufacturer: Showa
Tube diameter: 45mm
Claimed wheel travel: 4.7in.
Adjustments: rebound damping, spring preload
Rear suspension:
Manufacturer: Showa
Type: single shock
Adjustments: compression and rebound damping, spring preload
Tires:
Front: 130/70ZR16 Bridgestone Battlax BT50F
Rear: 180/55ZR17 Bridgestone Battlax BT50
Performance:
Time to distance 1/4 mile: 10.55 sec @132.74
Time to speed, sec.:
0-30 mph: 1.3
0-60 mph: 2.9
0-90 mph: 5.2
0-100 mph: 6.2
Top gear time to speed, sec.:
40-60 mph: 3.0
60-80 mph: 3.2
Measured top speed: 160mph
Engine speed at 60 mph: 3980 rpm
Horsepower: 120 bhp @ 10,500 rpm
Torque: 63.5 lb. -ft @ 8,250 rpm
Fuel Capacity (main/reserve): 3.75/1.0 gal.
Fuel Mileage (avg.): 41.7 mpg
Avg. range inc. reserve: 196 mi.
Braking Distance:
from 30 mph: 28 ft.
from 60 mph: 118 ft.
Speedometer error:
30 mph indicated: 28 mph
60 mph indicated: 56 mph
Old Oct 30, 2009 | 04:06 PM
scutfargas's Avatar
December 2011 ROTM
OK. It didn't keep my formatting and looks like stir fried shyt, but you all get the idea....
Old Oct 30, 2009 | 04:57 PM
Fireblade787's Avatar
Think it's a great idea. Can we also include tidbits that are frequently asked about each model or series. Like stock suspension settings, whll the fairings from this year fit on that year, etc...
I can crack open my manual later this evening and put the base info of my 919 (96-99??)
Old Jan 4, 2010 | 07:49 AM
maineiack's Avatar
Default 1996 cbr specs
1996 brought the first major changes to the CBR900RR. In order to achieve a more optimized balance of rigidity, Honda significantly altered the 1996 CBR's chassis and suspension. The frame and swingarm were fabricated from larger, thinner-walled extrusions for reduced torsional rigidity. The fork and shock internals were re-designed, and the swingarm pivot raised by 5 mm (0.20 in). Revised ergonomics brought the bars 10 mm (0.39 in) higher and swept back five degrees more than earlier models, along with a slimmer gas tank. Engine updates included a bump in displacement to 918 cc (56.0 cu in) via a 1 mm (0.039 in) bore increase, slightly higher compression, a curved radiator, larger muffler, extra clutch plates, smaller alternator, and the addition of a throttle position sensor. With the revised motorcycle came a revised name of CBR918RR. The 1996 model carried over to 1997 unchanged except for the updates to color/graphics offerings.
126.0 hp (94 kW) @ 10,500 rpm [1]
180/55-ZR17 rear tire
130/70-ZR16 front tire
4x 38mm Keihin CV carbs
71.0 mm (2.80 in) x 58.0 mm (2.28 in)
11:1 compression
918 cc (56.0 cu in)
quarter mile time:
CBR900RR ('96) 12/96 10.56 @ 130.0 n/a n/a 159.3
Old Jan 4, 2010 | 01:04 PM
MT Wallet's Avatar
I just wanna know if the pinholes in my fairings really improve the handling like Honda claims.
Old Jan 5, 2010 | 09:56 AM
maineiack's Avatar
from what i have read is that they are supposed to reduce wind resistance. making less friction between the bike and the air hitting. it . i guess it would help you carve through better. just a general thing that i read.
Old Jan 5, 2010 | 12:19 PM
MT Wallet's Avatar
Thanks for the info!
Either way, I think they look killer.
Old Jan 7, 2010 | 07:23 AM
maineiack's Avatar
u r welcome
sprocketjockey06
Jul 17, 2007 12:22 PM
nasty
Nov 28, 2006 01:20 PM
twelveOclockstandup
Mar 28, 2006 01:36 AM
latin
May 17, 2005 10:09 PM
Nipz
Jan 31, 2005 07:42 PM
