Specs
List Price: $8299
Liquid cooled four-stroke inline Four
Bore x Stroke: 70.0 x 58.0 mm
Displacement: 863cc
Compression Ratio: 11.0:1
Valve adjustment: 16,000 mi.
Carburetion: (4) 38mm Keihin
Battery: 12v, 8ah
Weight:
Tank empty: 432lb.
Tank full: 455lb.
Fuel Capacity: 4.9 gal.
Wheelbase: 55.0 in.
Rake/trail: 24.0/3.5in.
Seat height: 31.0in.
Ground clearance: 5.2in.
GVWR: 807lb.
Load capacity(tank full): 346lb.
Front suspension:
Manufacturer: Showa
Tube diameter: 45mm
Claimed wheel travel: 4.7in.
Adjustments: rebound damping, spring preload
Rear suspension:
Manufacturer: Showa
Type: single shock
Adjustments: compression and rebound damping, spring preload
Tires:
Front: 130/70ZR16 Bridgestone Battlax BT50F
Rear: 180/55ZR17 Bridgestone Battlax BT50
Performance:
Time to distance 1/4 mile: 10.55 sec @132.74
Time to speed, sec.:
0-30 mph: 1.3
0-60 mph: 2.9
0-90 mph: 5.2
0-100 mph: 6.2
Top gear time to speed, sec.:
40-60 mph: 3.0
60-80 mph: 3.2
Measured top speed: 160mph
Engine speed at 60 mph: 3980 rpm
Horsepower: 120 bhp @ 10,500 rpm
Torque: 63.5 lb. -ft @ 8,250 rpm
Fuel Capacity (main/reserve): 3.75/1.0 gal.
Fuel Mileage (avg.): 41.7 mpg
Avg. range inc. reserve: 196 mi.
Braking Distance:
from 30 mph: 28 ft.
from 60 mph: 118 ft.
Speedometer error:
30 mph indicated: 28 mph
60 mph indicated: 56 mph
Displacement: 863cc
Battery: 12v, 8ah
Weight:
Tank empty: 432lb.
Tank full: 455lb.
Wheelbase: 55.0 in.
GVWR: 807lb.
Front suspension:
Manufacturer: Showa
Tube diameter: 45mm
Rear suspension:
Manufacturer: Showa
Type: single shock
Tires:
Performance:
0-30 mph: 1.3
0-60 mph: 2.9
0-90 mph: 5.2
0-100 mph: 6.2
40-60 mph: 3.0
60-80 mph: 3.2
Braking Distance:
from 30 mph: 28 ft.
Speedometer error:
1996 cbr specs
1996 brought the first major changes to the CBR900RR. In order to achieve a more optimized balance of rigidity, Honda significantly altered the 1996 CBR's chassis and suspension. The frame and swingarm were fabricated from larger, thinner-walled extrusions for reduced torsional rigidity. The fork and shock internals were re-designed, and the swingarm pivot raised by 5 mm (0.20 in). Revised ergonomics brought the bars 10 mm (0.39 in) higher and swept back five degrees more than earlier models, along with a slimmer gas tank. Engine updates included a bump in displacement to 918 cc (56.0 cu in) via a 1 mm (0.039 in) bore increase, slightly higher compression, a curved radiator, larger muffler, extra clutch plates, smaller alternator, and the addition of a throttle position sensor. With the revised motorcycle came a revised name of CBR918RR. The 1996 model carried over to 1997 unchanged except for the updates to color/graphics offerings.
126.0 hp (94 kW) @ 10,500 rpm [1]
180/55-ZR17 rear tire
130/70-ZR16 front tire
4x 38mm Keihin CV carbs
71.0 mm (2.80 in) x 58.0 mm (2.28 in)
11:1 compression
918 cc (56.0 cu in)
quarter mile time:
CBR900RR ('96) 12/96 10.56 @ 130.0 n/a n/a 159.3
11:1 compression
918 cc (56.0 cu in)
quarter mile time:
