Put a 93 900 motor in my 98 900 HELP HELP HELP I am haveing wireing problems!!!!!
Old Jun 19, 2008 | 08:40 PM
mattyggstick's Avatar
Default Put a 93 900 motor in my 98 900 HELP HELP HELP I am haveing wireing problems!!!!!
Please help me on this one!! Ok, here it goes. I have a 1998 900rr that the motor blew on. So i picked up a 1993 motor and it fit and runs great. THE PROBLEM!! the 98 900rr had a speedo sensor on the motor and my 93 motor that I no winstalled doesnt. The 93 motor that is in uses the front wheel speedo sensor and cable. WHAT DO I DO?? Is there a conversion?? Do i get the front wheel speedo sensor, the cable, and a gauge cluster from a 1993 900rr, IF SO then will the rest of the gauges works Please help. I am new to this forum. You can email me at mattyggolfguru@yahoo.com or even call me at 860-608-3243. ANY HELP IS GREATLY APPRECIATED!!! Thanks so much guys!!!
Old Jun 20, 2008 | 01:06 AM
SpiritRR's Avatar
Default RE: Put a 93 900 motor in my 98 900 HELP HELP HELP I am haveing wireing problems!!!!!
Oh man...I'm sorry, but I think you are effed. If it were me, I would drop that 893cc and just wait for a good 98-99 motor to come along. If that is not an option, I would try getting a speed sensor and a drive sprocket cover from 95-97, and see if the speed sensor wiring could be spliced into your 98-99 wire harness.
The front sprocket cover for 95-97 (should fit right onto the 93-94 motor) has a notch in it where the speed sensor bolts onto the sprocket bolt, but the 93-94 cover does not (neither does 98-99).
The thing is, almost nothing carried over from 93-97 to 98-99. There's a good chance the gauge cluster will have no ****ing clue what you're trying to tell it by hooking up a 95-97 speed sensor, but it may work if you have a better understanding of electrical components than I do (which isn't to say a lot).
I recommend you don't try a 93-94 gauge cluster...there's nowhere to plug in your newer harness, and you would have to search for a 93-94 front wheel and cable. It's not worth it.
The absolute easiest thing to do, would be to get a 98-99 motor. I see 900RR engines about every other week on ebay.
Here, I just saw this tonight:
97 sprocket cover and speed sensor
Old Jun 20, 2008 | 01:42 AM
dinez74's Avatar
If your 93 motor can be fitted with the 96/97 front sprocket cover as what Spirit said complete with the speed sensor, you are lucky. The speed sensor for the 96/97 and 98/99 is the same anyway.
BTW you should had waited for a 98/99 motor.
Old Jun 20, 2008 | 09:48 AM
exz5string's Avatar
I've got a '94 (same engine as '93) and I've heard that you can change the stator cover for a '95-'97 to get the speedo sensor to work, in that case you'll also need the guage cluster from a '95-'97. Other option, no engine work option, is to get the front wheel off a '93-'94, speedo gear, speedo cable, and guage cluster for the same years and change all that out. I just got my standard system hooked up, took awhile to find the right front wheel, then had to put new bearings in it cause the old ones we're seized up. I rode all last season just not knowing how fast I was going, just kept up with the flow of traffic. I want to swap mine for the F4i guage cluster, but it involves the new stator cover, F4i guages, and since I finally got mine hooked up and working I'll hold off on that for awhile...
dustinjklee
F2 Tech
Apr 22, 2010 11:42 AM
svt954
Sep 2, 2009 08:43 PM
MobileMidget
May 6, 2009 01:36 AM
CBR929Stunter
Feb 20, 2009 02:29 PM
Hatebreed
Apr 20, 2008 07:26 PM
