Not flush mount, invisible mounted turn signals!
Old Jun 19, 2006 | 10:48 PM
DMACK's Avatar
Default Not flush mount, invisible mounted turn signals!
Here's what I did with Father's day.
This all started with adding some white metal wire in the holes in the tail of my 900RR. Then I thought it would look slick and streamlined with the rear turn signals imbedded inside the screened holes. I think it turned out sweet!
Here's alink to a video as well.
http://www.vfrdiscussion.com/forum/i...d=si&img=13855
[IMG]local://upfiles/6897/64CDA15C50E043EEBB08A90021F5415A.jpg[/IMG]
[IMG]local://upfiles/6897/5ED4817687BE474DAB2B1AEF4C29363C.jpg[/IMG]
[IMG]local://upfiles/6897/DA5A912103504479B0A978748DEB1E56.jpg[/IMG]
Old Jun 20, 2006 | 01:04 AM
cbr900's Avatar
Default RE: Not flush mount, invisible mounted turn signals!
damn, nice job bro, wish i could do that to my rr but i would'nt know where the hell to secure the signals. those look sic tho
Old Jun 20, 2006 | 02:01 AM
DMACK's Avatar
It was actually very easy. I even used the same signals I had on the back. They were the short stalk small oval replacement ones you see in every Cyclegear store. I bought 2 L shaped brackets from the hardware store. Then increased the angle to a little more than 90- degrees. I then drilled and tapped a 8/32 hole in the sub frame about 6 inches behind the seat. Extended the wiring and they were good to go. Less than an hour to install both.
The back end looks totally different!
Old Jul 15, 2006 | 03:56 PM
ch17011's Avatar
Nice mod - I did the same with my 94. I have the same color bikes as you - would you happen to know anyone with a fuel tank with the same white/black/red colors??
Old Jul 16, 2006 | 01:53 AM
DMACK's Avatar
Not off hand, but I'll keep an eye out for one!
Checkered Past
Aug 31, 2011 05:15 PM
freakyb
Apr 22, 2010 09:29 AM
ThisisMickey
Feb 18, 2007 09:52 PM
chris2ao
Aug 7, 2006 06:50 AM
wickedambush
Jul 13, 2006 03:15 AM
