NEED HELP ON TEMP.
Old May 8, 2005 | 11:10 PM
900rr crazy's Avatar
Default NEED HELP ON TEMP.
NEED A LITTLE HELP , WELL I GOT MY 900 WITH THE FAN DIRECT . AND I WANTED FOR IT TO WORK THE RIGHT WAY (WITH THE TEMP SENDING UNIT) SO I GOT IT HOOK UP BUT NOW IT RIDES TO HOT I THING . THE ONLY WAY I CAN LET U KNOW IS BY THE TEMP LETTERS ON THE CLUSTER. MINE IS ON THE FORTH LEG ON THE LETTER M . I THINK ITS TO HOT AND THATS WHEN THE FAN KICKS ON . SO WHAT DO I DO ?
THANKS FOR UR HELP.
Old May 10, 2005 | 03:16 AM
beater 900rr's Avatar
Default RE: NEED HELP ON TEMP.
that is were mine normaly runs maybe on the 2nd leg of the M. I am running a muzzy alm fan and all it will do for you is cool it down faster. if you are worried about the temp you might want to run a toggle and a temp sending unit. that way if you think it is getting to hot you can turn on the fan and if you forget the temp sending unit will get it.
my 2 cents
Old May 10, 2005 | 03:34 AM
OK, SO.... IT NORMAL . UR IS COOLER BECAUSE OF UR UP GRADE FAN RIGHT ? BUT I THINK IM GOI TO DO THE SWICH . JUST IN CASE IT GET TO HOT FOR ME
THAKS FOR UR HELP . LOVE THE UR BIKE MAIN IS LOWER AND ITS ALL YELLOW AND EXTENDED 8 INCHS
WangDangger
Apr 27, 2012 12:17 PM
codye352
May 29, 2011 03:02 PM
onefastRR
Apr 6, 2010 08:58 AM
02hondacbr954rr
May 21, 2008 09:45 PM
