Need help installing a Regulator Rectifier
Old Mar 26, 2009 | 01:39 PM
CBRKing's Avatar
Default Need help installing a Regulator Rectifier
Hey guys,
Im new to the forum and I was needing some help on how to install Regulator Rectifier on my 1998 Honda CBR 900rr. i know basic knowledge of motorcycle maintenance and just want to make sure im taking the right steps to doing this...
Old Mar 26, 2009 | 02:55 PM
hondachris1994's Avatar
take ground off battery, then unplug harness goin to the old rectifier, unbolt it, bolt the new 1 on, then plug harness back in, then reconnect ground and u r done. Simple as that
Old Mar 26, 2009 | 03:45 PM
CBRKing's Avatar
thanks for the help chris also i wanted to ask should i leave the battery or can i take it completey out...what is that tool i need to buy to check how many volts my bike is putting out
Old Mar 27, 2009 | 09:01 AM
exz5string's Avatar
no reason to take it out unless you really want to, just disconnect the ground wire. you need a voltmeter for the test, check it with the bike running and then again with it off, should be about 12v off and closer to 14V running, 13.7-13.8V I believe. I replaced mine and checked it before I replaced it just to see the difference, running before replacing it was less than 11V, didn't even charge the battery at all.
Old Mar 27, 2009 | 11:05 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Welcome to the board! When you get a minute post up a thread in the new member area so peeps can give you a proper welcome. They'll want to see pics of your ride so be prepared!
Monkeybutt2000
Jun 21, 2011 12:49 PM
raiden
Jul 8, 2010 09:18 AM
HurricaneSlim
Jun 28, 2010 03:24 PM
blacksmith_28352
Jul 31, 2007 10:51 AM
Trips
Jul 5, 2007 05:45 AM
