Need help installing a Regulator Rectifier
no reason to take it out unless you really want to, just disconnect the ground wire. you need a voltmeter for the test, check it with the bike running and then again with it off, should be about 12v off and closer to 14V running, 13.7-13.8V I believe. I replaced mine and checked it before I replaced it just to see the difference, running before replacing it was less than 11V, didn't even charge the battery at all.
1994, 1998, 900, 98, cbr, cbr900rr, find, honda, install, installing, located, motorcycle, rectifier, regulator, regulatorrectifier
