My turn signal issue...
Not sure if anyone remembers my turn signal issue from last year...
https://cbrforum.com/forum/cbr-900rr...10/#post967283
ANYWHO... I got it fixed, for the most part. I started by getting 3-wire fronts like I needed and an LED flasher. That fixed it for the most part BUT when I would use a turn signal, the opposite side would dimly light up as well. So, it always looked like hazard lights for the most part.
Got annoyed, took the entire harness out of the bike, went over every wire and found nothing wrong, re-loomed it, put it back in and still had the problem. Ended up yanking the bulb out of the "turn signal indicator" on the gauge cluster and that fixed the problem. Now, my signals work fine but I can't have a bulb in the indicator on the gauge cluster or it won't work right.
Anyone have any ideas why that is?
