Low rpm when started and stalls
Old Jan 25, 2009 | 11:55 PM
kashyfla's Avatar
Default Low rpm when started and stalls
Sup everyone Sean here again with trouble on my 95 cbr 900rr. When I start up my bike the rpms are between 700-500 and drops lower until I push some gas on it. For the past couple days i've been starting up my bike like this putting a little gas until it warms up and doesn't stall. Its kinda frusterating cause I need to push some gas on the start up or it will stall. Anyone have a clue on what the problem is? Also there a little of a kocking nosie when the rpms are low. My rpms are also at this level while idleing at lights. Could it be the cam chain tensioner or something inside the engine that could be causing this time consuing annoyance? I also forgot to mention that I have a Keiman aftermarket carbeurator installed into this bike. I can't seem to find the choke but there is this **** in my left side engine that turns left and right. Doesn't say anything on it but if I ride with the bike while the **** is switch to the right, my bike jerks a little if I don't push some gas while riding. Compared to having the **** turned left, the bike rides without me pushing anymore gas while riding. So could this be the choke? I tried starting up the bike with left and right turned and still the bike does the low rpm and stall thingy. Someone please help me ahh~~..
Sean Chan
Old Feb 8, 2009 | 07:53 PM
camaropower's Avatar
It sounds like you need to adjust your idle to me? Only problem is with aftermarket carbs I don't know if the idle screw is in the same place as mine, (I have a 95 900rr too, stock) I'm not sure what button your talking about either that goes left and right. Also my choke is to the right of the clucth perch if you were sitting on the bike
BRNFNY
Apr 4, 2014 05:45 PM
DesertCBR
Apr 23, 2012 07:19 PM
dooknook
Sep 13, 2010 07:16 AM
SDCBR600F4
Jun 15, 2010 12:11 AM
SloNotch
Jul 27, 2009 08:59 PM
