LED Instrument Cluster conversion??
Old Apr 4, 2011 | 04:49 PM
grubeda7's Avatar
Default LED Instrument Cluster conversion can be done
Anyone here every change their bulbs in the instrument cluster to LED? Im having a hard time finding the right size/height that will fit in the circuit board. Any ideas?? Thanks in advance!
Old Apr 4, 2011 | 05:33 PM
jeffjones's Avatar
I did a thread on changing them for an F4i:
https://cbrforum.com/forum/how-mecha...luster-119967/
If they are the same then it has all the part numbers for the different colours.
Hope it helps!
Old Apr 4, 2011 | 05:39 PM
grubeda7's Avatar
Thanks but it is a different setup in the F4I, there are no LED's on in this one to start off. Just normal bulbs that illuminate the whoel inside of the case. These are twist in bulbs
NeoWedge series LED Lamp Specifications
Problem is these are too tall and wont work. Only place Ive found so far.
Old Apr 5, 2011 | 03:31 PM
vfrman's Avatar
Party Animal, ROTM June 2014
Yep, I did it. The link you provided is exactly what I used. Just remember that they are polarized so if they don't work, take them out and re-install 180 degrees. I used the high power SMD ones, but I had to order a std power blue for my high beam because it was stupid bright. I replaced all my bulbs. The backlight were only for the needle because I have some elglow gauge faces in mine. I couldn't read the kph (need it in Italy) on the stock face.
Old Apr 5, 2011 | 08:48 PM
grubeda7's Avatar
Which exact bulb did you order? Ive all ready ordered the 4mm LED but that was too big so I returned.
So Im guessing you got the 3mm SMD led? And So for behind the tach and speedo you didnt use any because you have lights faces?
which bulb did you get to fit under the gauge face exactly i guess is my question.
Thanks for all the help man!!!
Old Apr 9, 2011 | 08:08 PM
grubeda7's Avatar
Well, For anyone looking to do this mod. Its fairly easy and its not to expsensive. If anyone is interested I'll post up pics and tutorial.
Old Apr 9, 2011 | 09:05 PM
NastyNinjaBear's Avatar
Id be interested. If you could that would be great!
Old Apr 9, 2011 | 11:22 PM
SGTSKiP's Avatar
Got it on the other site..... several guys on here have done it.
F4i digital gauges onto a 900RR! - RRZone Forums
Sgtskip, on both sites
Old Apr 10, 2011 | 02:41 AM
Ooo. I'm so going to do that.
aaront1988
Jul 12, 2013 08:29 PM
Boffo71
Jul 15, 2008 11:08 AM
530Chain
Aug 11, 2006 02:38 PM
blown
Nov 7, 2005 04:03 PM
