Instrument Cluster
Old Jul 12, 2013 | 11:45 AM
aaront1988's Avatar
Default Instrument Cluster
Is the cluster pretty much a plug and play unit? I've damaged mine in a spill and it's busted the connection plugs. If I was to buy one of ebay would it work or would I need to get it reprogrammed etc etc?
Cheers
Old Jul 12, 2013 | 12:54 PM
freestylemotox12's Avatar
yeah it is plug and play, no programing needed, if you damaged the connectors on the ecu side of the harness you may have some problems but if thats the case let me know i i think i have an extra harness laying in the garage from my f4 to f4i engine swap.
Old Jul 12, 2013 | 01:27 PM
aaront1988's Avatar
You're a good man!! It's the actual connectors on the speedo unit however I've spent an hour or 2 straightening all the pins and seem to have had some luck. Bad news is I've damaged the casing (instrument housing) though, so will need to hunt down one of those. Rocking horse crap comes to mind!
Old Jul 12, 2013 | 02:20 PM
bigboi18184's Avatar
you should be able to get just the case at either ronayers or bike bandit for under $100
or buy a used one that's close in mileage
Old Jul 12, 2013 | 08:29 PM
I saw a case on eBay a couple weeks ago pretty cheap, I don't know if its still there or not but you could check
bazacko
F2 For Sale / Trade / Wanted
Sep 10, 2012 12:56 PM
rell123456
Jan 25, 2010 11:33 AM
Paul Square
Oct 16, 2006 12:21 PM
bigef4i
Apr 28, 2006 10:06 PM
