how to blow an engine....avoidance issues
Old May 28, 2007 | 11:56 AM
900nos's Avatar
Default how to blow an engine....avoidance issues
recently developed issuewith shfiting,mine can "pop/hit neutral" in second/third/4th/5th..
its only when i'm screamin thru the rpms it happens, 8000--10,500 before this happens,
think it might just be the output shaft with the front sprocket missing a tooth?coming from trans gears.
its a real b@#$% to be on the bottle and this happens, nos dosent understand the gas has throttle's been cut and theres a
hair delay before whats in the intakes/chambers gets used, in otherwords really working on not throwing all internal parts
through every side of the bike.because it comes out of gear.
any suggestions please reply,, thanks
michael
Old May 28, 2007 | 03:59 PM
bindelsf2's Avatar
Default RE: how to blow an engine....avoidance issues
do a search on here for shift forks....thats the same problem thati had it is your shift forks.. there is a write up i have on how to replace them to that i found on here if you want it..
Old May 28, 2007 | 04:00 PM
bindelsf2's Avatar
i saved you a little leg work!
https://cbrforum.com/searchpro.asp?p...bmitbutton=+OK+
Daniel Coleman
Jun 5, 2014 04:31 PM
cbrfxsmithy_6_7
May 18, 2013 02:52 PM
tzr3
Apr 6, 2010 01:18 PM
jalate compa
Dec 12, 2007 10:04 AM
Jet Jockey Z06 Vette
May 6, 2006 06:04 PM
