engine sucks instead blow help
Old Dec 11, 2007 | 07:52 PM
jalate compa's Avatar
Default engine sucks instead blow help
hi i repair a broken valve, it was broken because bad shims calibration. it was fixed with good seat and the all shims where calibrated on 10, then i put the all the bike togeter and it starts for about 1 minute then the engine just died so i took of spark plugs and i hit the starter buton while i was covering the spark plugs holes with my hand and i feel how every hole suck my hand instead blow my timming is perfect i dont know what happen im so confused any ideas???[][]
Old Dec 12, 2007 | 12:05 AM
Sand.Man's Avatar
Default RE: engine sucks instead blow help
Umm... That's the force that draws fuel and air into the cylinder. It sucks AND blows, it's called the vacuum effect, it's how syringes work.
Old Dec 12, 2007 | 10:04 AM
CBR13F2's Avatar
your shims must be off or your timing. Engine sucks on down stroke through the intake valves while they are open. Then intakes close and exhaust opens on up stroke so it should blow out. My guess timing and shims.
96MTBike
Dec 16, 2013 02:59 AM
dont under estimate 1 liter
Sep 11, 2013 02:08 AM
NateDieselF4i
Feb 16, 2011 12:57 PM
900nos
May 28, 2007 04:00 PM
toyotafj40s
Nov 21, 2006 09:27 PM
