Honda cbr 900 rr 94 model
Old May 21, 2021 | 03:54 AM
Shanman's Avatar
Default Honda cbr 900 rr 94 model
I was riding down the road and all of a sudden my bike died so I pulled clutch in amd came to a stop it want crank in gear now I put it in neutral and light comes on and then it will crank I put it in gear amd it dies the neutral switch looks like it’s good amd the kickstand light works good too they both cut on and cut off like they are suppoosed too this hear really got me I’ve un plugged all the sensors by the headlights amd the bike still cranks just when it in gear it dies need some answers please
Old May 21, 2021 | 07:28 AM
Hi Shanman,
Please take a moment to introduce yourself to the forum.
Where are you from, how long have you been on two wheels, what bikes do you have etc.
We also love pictures.
It sound like it is one of the safety switches, probably the side-stand that is playing up which would cause it to cut out when selecting a gear.
I'm sure one of the guys with a blade will chime in, but that circuit is where I would start looking.
Cheers
​​​​​​​Al
Old May 21, 2021 | 12:30 PM
The Side Stand switch has 2 functions. In the down position, it provides a ground connection for the Side Stand Bulb to make it light up. In the up position, it provides a ground for the ECU to tell it that the Side Stand is up. Need to check to see if the Green/White wire on the Side Stand switch is being provided a ground connection. If not, then Side Stand switch is most likely bad. So, G/W wire should have 12v present when Side Stand is in Down position, and 0v on G/W wire when it's in the Up position. These wire colors are accurate for the 1996-1999 CBR900RR. Not 100% sure on 1993-1995 years.
Cognac
Apr 20, 2012 04:19 PM
BTBTBT
Jul 11, 2010 02:46 PM
face
Jun 26, 2010 04:04 PM
96@cbr
Nov 14, 2009 12:56 PM
renegadef4i
Sep 21, 2007 06:27 PM
