hesitation
Old Apr 24, 2007 | 01:41 PM
Axl5's Avatar
Default hesitation
I am out of idea. When the bike is warm or when i wait on a red light or stop at a stop sign,the RPM will just drop andrun very badand when i want to go ahead, the bike ( 1994, 900rr)
hesitate a lot . I have to let the clutch slipped. I did try everything and change everything. The only thing left is to look at coil ect...
Need some help.
Old Apr 24, 2007 | 02:04 PM
Mad Hatter's Avatar
Default RE: hesitation
Sounds like mine when I put a new pipe on it. It needed a re-jet. Does it run better at cruise speeds or higher RPMs?
Old Apr 25, 2007 | 12:15 AM
Meeks's Avatar
Is the idle set too low? Try turning the idle know (on the left of the bike) in just a hair.
Old Apr 25, 2007 | 01:29 AM
HAVOC's Avatar
just curious are you having trouble starting your bike ?
Old Apr 25, 2007 | 10:29 AM
Axl5's Avatar
It is running great at cruise or high rpm. It's only when i want to go from a dead stop.The bike start great first try every time.
I own this bike since 1999 and never had a problem with it. It strat about a year ago. My idle is set at 1300 rpm+/-.
When i start the bike, he is running great for about 10 min and as soon as he gets hot, that is when the problem start.
I changed the plugs, gas filter, clean up the carbs, air filter....I am thinking of buing a new set of jets and main and change everything again.
Old Apr 26, 2007 | 11:44 AM
gixxereater's Avatar
Is the petcock working correctly? My diaphram was torn and gave me some issues. Perhpas the coils are to blame. When they get warm from sitting with the engine cooking them they may start mis firing. Just a couple of thoughts.
Old Apr 26, 2007 | 12:11 PM
Axl5's Avatar
That's what i was thinking. I will check at the voltage when they are hot
Thank's.
Old Apr 27, 2007 | 10:42 AM
chrisf's Avatar
It also sound like the motor is ingesting a lot of hot air. As the speed increases, it washes the hot air out of the airbox--assuming you're running an airbox.
But check the coils first.
--Chris
Old Apr 27, 2007 | 01:19 PM
Axl5's Avatar
Good point. I did take off that plastic plate in front of the 2 air box intake few years ago.
Old Apr 27, 2007 | 01:29 PM
Axl5's Avatar
Good point. I did removed that plastic plate that is under the 2 air box intake years ago.
BTBTBT
Nov 10, 2010 09:09 PM
pitcru05
Oct 15, 2010 11:20 AM
exopforce
Sep 10, 2009 01:51 PM
HV Racing
Mar 8, 2009 11:35 PM
rrasco
Aug 2, 2006 05:47 PM
