Help! My 98 900rr is SICK
Old Jul 18, 2006 | 11:28 PM
iluvdalaydees's Avatar
Default Help! My 98 900rr is SICK
I HAE A 98 900RR AND WHEN I TRY TO CRANK ON THE FIRST TRY IT WILL TURN OVER CRANK AND CUT OFF. THEN WHEN I HOLD THE THROTTLE TO CRANK IT IT WILL, THEN I HOLD THE THROTTLE FOR A FEW SECONDS AND LET IT GO AND IT WILL IDLE, WHAT COULD I DO TO MAKE IT RUN RIGHT?
Old Jul 18, 2006 | 11:41 PM
japanese900rr's Avatar
Default RE: Help! My 98 900rr is SICK
Well I think you have to start by telling us... whether you mean a cold start or warm start = Whether the engine is warm or does it occur EVER time you start your engine?
How does it run normally? Do you have to hold the throttle even with choke on? How badly does it idle once it runs? Basically, with anything that runs on gas start with the basics... Fuel, Air, then Electrical.... in the end when all else fails you go deep mechanicals like checking engine compression etc. Start with as simple as the fuel filter inside the tank and then the fuel filter on the line then the fuel pump...
Carburator calibration... cleaning... rejetting... and so forth.
When you get your hands on a Factory Service manual, all the simple things are on it and how to diagnose the troubles. Anybody that can tell you what's possible wrong with the bike without looking at it must be a psychic or genious!
1BAD14
Nov 14, 2011 07:07 PM
Mrmanr
Mar 12, 2011 01:02 AM
CBRCRF
Sep 7, 2007 11:47 AM
BlindinOrange
Sep 1, 2007 08:31 AM
telgren
Nov 23, 2006 12:28 AM
