Gear engagement from standstill
Old Jun 7, 2007 | 01:51 AM
cloudbreakmd's Avatar
Default Gear engagement from standstill
I noticed that my CBR kind of clunks in gear when I shift into first from a standstill. I am concerned that my clutch cable is out of adjustment but am not sure if this is just a trait of the bike. Gear changes while moving seem fine (hard to tell if there is a problem there anyway) but, thought I would ask.
Thoughts?
Old Jun 7, 2007 | 03:08 AM
rideordie!'s Avatar
Default RE: Gear engagement from standstill
your clutch lever is adjustedin too far. loosen the adjuster locknuton the handlebar and turn the adjust out about 1/2 turn, then retighten the locknut. you should be good to go. p.s. if the adjustment on the handlebar is already out all the way you will have to adjust it on the other end.
Old Jun 7, 2007 | 07:50 AM
bindelsf2's Avatar
mine clunks too and i have tried to adjust the clutch lever alot, but i also havea bent shift fork which could be contributing to it..
Old Jun 7, 2007 | 10:42 AM
gixxereater's Avatar
Every bike clunks a certain amount. It's the transmission clunking a little as well as pulling the slack out of the chain, etc. It's normal unless it's JUMPING forward when you engage 1st.
Old Jun 7, 2007 | 05:43 PM
It jumps forward just a little. I will take a look and get back to you guys on this.
Trent Dog
Jul 9, 2012 06:32 PM
patmetz
F2 Tech
Oct 15, 2010 10:31 AM
Stray Cat
Sep 21, 2006 10:28 AM
steve00ses
Feb 23, 2006 08:15 AM
