front rotor bolts
Old Mar 31, 2009 | 07:42 PM
eukanuba517's Avatar
Default front rotor bolts
Does anyone know what size hex head you need to remove the front rotors? Also my throttle cable stick open. I am going to oil the cable and chech the throttle assembly. can anyone tell me if the other end runs into the carbs at all, or does it to a bar?
Old Mar 31, 2009 | 09:43 PM
camaropower's Avatar
I'll check the allen size in the morning, its definately metric. The throttle cable runs into a bracket right in the middle of all four carbs. Make sure that your bar ends aren't too tight as well. Mine stuck open on me because my clip-on was slightly bent
Old Mar 31, 2009 | 10:50 PM
RR MIKE's Avatar
2 cables from right bar,both go to center of carbs,1 is pull other is return or 1 cable opens,the other cable closes throttle blade in carbs.
They are seperate cables and can be adjusted at bar,but best if you adjust at carb.If you adjust at carbs,you will need 10mm wrench.
You sure the choke cable is not stuck? they stick from time to time.
Old Mar 31, 2009 | 10:56 PM
RR MIKE's Avatar
Oh yea and rotor allens are 6mm,make sure to heat them up with small torch,get them warm to touch,not cherry red.Will come off easy when lil HOT!!
Krux
May 18, 2010 10:22 PM
stinkpalm
Jan 6, 2010 01:05 PM
BlindLOKI
Apr 9, 2006 11:08 PM
chainstretcher
May 2, 2005 10:08 PM
