***Rotor bolts -- warning***
Old Apr 30, 2005 | 08:18 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default ***Rotor bolts -- warning***
I don't care if the manual does say 14ft/lbs it's fargin wrong[:@] Should be 8ft/lbs -- those frikkin pan head bolts snap like a **** at 14ft/lbs.
Old May 2, 2005 | 08:09 PM
NeonspeedRT's Avatar
Default RE: ***Rotor bolts -- warning***
Sounds like you found out the hard way
Old May 2, 2005 | 09:07 PM
L8X's Avatar
L8X
what happened dude?
Old May 2, 2005 | 10:08 PM
Well in order to change a tire I had to remove one rotor. Get tire mounted and put rotor back on. Check manual for torque specs. 14 ft/lbs. I double check as this seems high for 6mm bolts. Yes, it is 14 ft/lbs. Set the wrench at 8 ft/lbs and tighten criss-cross pattern. Re-set at 10 ft/lbs and SNAP -- WTF???? So I go to the next one (like a dumbass) and SNAP. So I re-re-check and yes it's 14 ft/lbs. So I get my trusty nut and bolt book and it says for 6mm bolts:
grade 5 max torque 5 ft/lbs
grade 8 max torque 6 ft/lbs
So Honda screwed up in the book. I had some extra 6mm bolts and a bolt extractor -- got 'em out easy enough and ordered all new from the stealership at $32.
Just a friendly post to let you know not to follow that direction -- also if that little voice in the back of your head says "This don't sound right" check with another source of info before proceeding.
Krux
May 18, 2010 10:22 PM
stinkpalm
Jan 6, 2010 01:05 PM
eukanuba517
Mar 31, 2009 10:56 PM
BlindLOKI
Apr 9, 2006 11:08 PM
