Front End wiring questions
Old Mar 5, 2007 | 11:02 PM
Manic's Avatar
Default Front End wiring questions
I am checking the wiring and trying to find out what's going on. The bike used to have an aftermarket headlight system on it. Between all the cutting and splicing, and the bike being in pieces, I don't know what these wires are for.
Photo 1) The wires are white and black in the middle of the photos. These wires are coming from the engine towards the front. Are these the turn signals for the right side?
2) This is on the same run, but higher up towards the gauge cluster. Is this for the "middle" head light?
3) I think two of these are for the left turn signal, but I don't know what all the mess is going on.
Help?
Thanks
Old Mar 6, 2007 | 01:35 AM
johnnyh's Avatar
Default RE: Front End wiring questions
I,ve done everything with an ohmeter tester and a test light and the way I wired my head lights is using the white lead coming out of the headlight switch to the low beam and the blue to the high beam whitch also goes to the cluster gauge. My signals are next. I will let you now. Johnny
Old Mar 6, 2007 | 12:09 PM
Manic's Avatar
I still have the connections for the headlights. I didn't do a ohm test, but when I plugged in the headlights, the left one was really dim. Didn't make a differance if I had the high beam on or not, still dim. When I get home from work, I was going to just double check the connections. Would you let me know what your get for yours?
Ace21
F2 Tech
Jun 20, 2011 09:54 PM
lino129
Nov 6, 2009 10:19 AM
madeincanada123
Apr 3, 2009 10:16 PM
stalkin
Mar 26, 2009 05:24 PM
morganater
Jul 20, 2006 02:22 AM
