Fairing Conversion ( 94' 900r to a 97' 900rr or higher)
Old 06-24-2008, 09:54 AM
gxsretr's Avatar
Default Fairing Conversion ( 94' 900r to a 97' 900rr or higher)
Hey guys, my buddy got a 94' 900rr last week and he wants and 97 or higher conversion done on the fairings. Any ideas or knowledge would greatly be appreciated. Thanks in advance.
Old 06-24-2008, 08:46 PM
Default RE: Fairing Conversion ( 94' 900r to a 97' 900rr or higher)
Its possible to convert the front cowl and the tail to a 98-99 model. The front cowl bracket need to adjusted and make it longer to to place the speedo and yes you need to replace the headlight as well.
Old 06-25-2008, 07:02 AM
gxsretr's Avatar
Hey thanks alot!
Old 06-25-2008, 09:39 AM
Jeff1980's Avatar
He'll also need the correct mirror stay. If he's going with a '95-'97 upper, he'll need the '95 stay. It mounts to the frame in the same spot as '93-'94 but matches up to the fairing propperly. If using a '98-'99 upper he will need to build a small bracket to allow for the frame portion of the mirror stay mountmount, or drill and tap the frame. Either will work fine and is really a lot more simple than it sounds. Also, he's going to need the corresponding inner fairings as they are different with each style upper.
Old 06-26-2008, 12:31 AM
Ok here we go I make a tail section for that bike thats just sick
and you can mod a F4I front to it with out allot of work it will bolt upt to the stock mids
Old 06-26-2008, 05:57 PM
what!? that is sick!! what do i need? i have a 96 900 i wanna put the f4i front end on it
RR MIKE
07-14-2022 12:52 PM
Expert116
01-16-2010 11:14 PM
otello
10-08-2009 09:50 PM
Quick Reply: Fairing Conversion ( 94' 900r to a 97' 900rr or higher)
