Fairing Conversion ( 94' 900r to a 97' 900rr or higher)
RE: Fairing Conversion ( 94' 900r to a 97' 900rr or higher)
He'll also need the correct mirror stay. If he's going with a '95-'97 upper, he'll need the '95 stay. It mounts to the frame in the same spot as '93-'94 but matches up to the fairing propperly. If using a '98-'99 upper he will need to build a small bracket to allow for the frame portion of the mirror stay mountmount, or drill and tap the frame. Either will work fine and is really a lot more simple than it sounds. Also, he's going to need the corresponding inner fairings as they are different with each style upper.
