Engine Knocking
Old Nov 8, 2007 | 09:14 PM
SpiritRR's Avatar
Default RE: Engine Knocking
ORIGINAL: petrorr
add an off balance washing machine on spin cyclewith a couple of good sized rocks in the dryer add smoke and thats what the potential disaster sounds like
You're scaring me at the same time as making me laugh. [:-] I feel...strange, chuckling at your description of a bloody, attempted murder scene. Now I want to run to the garage and check on my own child's bearings. Apparently 893 and 919 are dangerous area codes for rod molesters, and I live smack dab in the low mileage part of 893 town. Frightening.
Old Nov 14, 2007 | 02:14 AM
petrorr's Avatar
Yeah I found it funny too...I dont know why, it just popped outta my head...I laughed too after I read it...lol
Old Dec 10, 2007 | 09:43 PM
97CBR900RR's Avatar
Ok so got everything completly apart and indeed it spun another damn bearing...... :-( this time rounded out the rod and rod cap.... got new rod and cap. also found out bike has high comp. pistons, upgraded cams, and boared 20 over.... lol. only issue me and everyone i talk to is stumped about is my crank journals are reading at 37 mm. My book shows 34 for the largest..... how in the hell does it get bigger!?!
Old Dec 10, 2007 | 10:55 PM
SpiritRR's Avatar
I think we have the same book because it clearly states that the inside diameter is supposed to be 37 and the OD is supposed to be 34. How is that possible? Are the Clymer laws of physics different than Einstein's? Shouldn't it be the reverse?
Old Dec 10, 2007 | 11:00 PM
97CBR900RR's Avatar
See thats exactly my problem. And i called one of the repair shops up here and talked to a guy and he said his book showed that the max was 36.5 mm. So now i really dont know what to do cause im sending the crank in the get re surfaced and all but need to give them the specs. but dont see how i can if they are unkown.... hmmm........ Anyone got anything?
Old Dec 11, 2007 | 01:17 AM
SpiritRR's Avatar
Okay, yes, I am a derfus. 37mm is the interior diameter of the crank case--where the bearings that surround the journals sit. The 34mm outside diameter is what you thought, the OD of the journal itself. So if you take the 34mm journal and add a bearing, you're now taking up 37mm of total interior crank case diameter.
So yeah, go with the specs in your book.
Old Dec 11, 2007 | 08:13 AM
97CBR900RR's Avatar
Ok well ya that would make sense for it to be 37 mm with bearings but its 37 mm now completly bare with nothing on it.... and i put the plastic gage in and squezed it and it flattened up to good spec. but one of my journals where the bad bearing was got worm down to 36mm. So if i had the crank re- done to spec at 34 mm like the book says wouldn't that make it way too small for my rods considering there assuming to be ok at 37 with the rest?
Old Dec 11, 2007 | 08:58 PM
SpiritRR's Avatar
So whoever bored the cylinders and did all the other work stuffed a larger crankshaft in there too right, I mean the OEM size is definitely 34mm, so if yours is 37, then the case would have to have been bored larger too. Are you able to measure the case itself, where the main journal bearings sit. If they're not at least 40mm, then something really stinks.
As far as the one journal being a mm down, I don't know what you could do with it. You're kind of stuck, what with larger cylinders and the other journal sizes. There may be a solution, but it would have to come from someone who does this on a daily basis--and is good at it. Perhaps post in Gen Tech, I know there's some car engine guys, ThirdGenlxi comes to mind (though he does American diesels).
Plus I'm just not getting very good vibes from the story of your engine. As capable as you are, I would seriously consider plunking down for a good, used motor. I see one about every 2-4 weeks on ebay, some that I would really want myself. Prices are decent, anywhere from 500-900, usually closer to six. I would at least think about it before you drive yourself up the wall trying to resuscitate this one. [:-]
Old Dec 12, 2007 | 12:04 PM
97CBR900RR's Avatar
lol ya i see what your saying. Its just mind blowing and driving me completly insane. The only reason that i don't want to just buy a new motor is because of all the upgrades already done to this one.... But who knows maybe i can sell the upgrades and get enough off them for a used motor. Who knows this is just one huge headache. lol
Jaybyrd
Jul 11, 2010 09:44 PM
Kc31019
Aug 30, 2008 12:41 PM
wheeler6747
Mar 24, 2008 11:28 AM
Ueafa
May 29, 2007 11:45 PM
four.six
Nov 27, 2006 05:42 PM
