electrical
Old Mar 16, 2009 | 10:50 PM
jwitham52's Avatar
Question electrical
My low beams quit working and my high beams dim at idle...Is this a stator problem or rectifier or what???? My bike is a 93 900 RR. Thanks for any help.
Old Mar 17, 2009 | 05:54 PM
900FighterRR's Avatar
do you own a DVOM or volt meter? A test lead? If you don't have these two items then your not gonna get real far diagnosing this issue. If you have them then check your grounds and look for resistance on the circuit. Also, the your headlight connectors (plugs) could be corroded and causing resistance. Check your charging voltage at and above idle, and see how much voltage your getting at your bulbs. Electrical diagnosis is done systematically from the point of the problem back. There are at least 50 things that could cause your problem, so like I said, either get the tools or pass this on to a pro.
Old Mar 24, 2009 | 03:26 PM
DMACK's Avatar
make sure you charge the battery before you start the testing. A weak battery will throw off the tests.
kani73
Jul 31, 2011 04:25 PM
zapp109
Apr 1, 2010 12:18 PM
drown42
Aug 26, 2009 04:06 PM
skitzofrenzy
Sep 22, 2008 04:21 PM
travsstuff
Dec 4, 2007 11:51 PM
