Ebay Plastics / Fairings
Old Mar 13, 2008 | 06:27 PM
pixel 6's Avatar
Default Ebay Plastics / Fairings
Anyone had experience with em? Fitment? cost? Quality?
Helping a friend shop for new plastics, and want to steer him in the right direction.
Here's the link for one of em from like korea or somehting... the 500 dollar with shipping ones.... I've heard good and bad about these... your thoughts?
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
Old Mar 13, 2008 | 06:40 PM
pixel 6's Avatar
Default RE: Ebay Plastics / Fairings
One more question on this... what years are the fitment the same? like 95-97, then like 97-? So how does that work? Are the plastics from year to year interchangable? Or will there be mounting problems if I get outside the year 96.
Thanks.
Sorry for babbling.
Thanks again.
Sorry for continuing my babbling....
I should go now.
Thanks.
again, and again.
- Pixel -
Old Mar 14, 2008 | 06:46 AM
Jeff1980's Avatar
They'll all fit but you would need a different upper fairing stay, mirror stay, headlight and rear seat if you use '98-'99 parts. I never used these on a 900rr but I did put a set on an '05 600RR. I will NEVER do it again. It was a pain in the @$$ and some ofthe parts just would not fit right no matter how much tweaking I did. For instance the upper filler panels (ram air covers) just wouldn't mate up to both the gas tank cover and the upper so there were these little gaps that really bothered me. Also, there were no mounting points for the headlight,I had to make them. Plus, the plastic is thinner than factory so anywhere you use the factory shouldered bolts the fairings will rattle around if you don't put some nylon washers on.
If you do choose to go this route post your experience on here. I've been curious if it was just the model I dealt with or if all of that plastic is like that.
Here is a pic of the part that wouldn't fit right. I know it looks like no big deal but it really bugged me. This wasn't the only part that wouldn't fit propperly at first, I had to customize almost everything....... This is just the only piece I coldn't get to look okay no matter what I did.
[IMG]local://upfiles/20679/11993BC7C0D04274B4232A16B729E8F2.jpg[/IMG]
[IMG]local://upfiles/20679/65986DA8AF8A46C48B570FBD7D1C37E0.jpg[/IMG]
Old Mar 14, 2008 | 08:31 PM
slimmyslim1420's Avatar
If you look around on there a little more you might be able to find something better. I found an aftermarket front that had all mounting tabs and was plastic for a little over $100 on there. But if you are good with body work these would work for you. Otherwise I would look for something different.
Old Mar 29, 2008 | 09:57 PM
rons93rr's Avatar
i put a set on my 93 900rr the set was for 94-97 asian modles so i had to purchase an upper w/mounting tabs for the headlight.
i bought from the same exact dealer in your link. i still have a little tweeking to do but some of the gaps like around the rear seat are fairly large over all i think that the bike looks great however the bottom of the fairings where they meet the v-fairing don't line up(i'm still working on that, but for the $ not bad. it is a bit of work though.
matty
Aug 13, 2007 09:26 AM
Aziz
Jul 18, 2007 12:13 AM
Ruthless
Jun 22, 2007 05:30 PM
xrvapunkx
Jun 15, 2007 01:21 AM
pagetom76
Dec 15, 2006 02:54 PM
