clutch question
Old Mar 15, 2008 | 05:13 PM
bindelsf2's Avatar
Default clutch question
so i have just gotten done rebuilding the engine on my bike full top to bottom. and my question is i have absolutely no pressure on my clutch... the lever will go all the way to the grip and it is super flimsy and the cable doesnt "pop" back at all.. i can move the lever on the clutch cover and it snaps back barely but there is barely any pressure to it and it used to be a good hard snap back..
so do you think that once i get the engine started and fluid flowingthat it will tighten up properly or should i start taking it apart to double check everything??
i have looked at the manual and online microfiche and everything looks perfect..
Old Mar 15, 2008 | 06:17 PM
bindelsf2's Avatar
Default RE: clutch question
one more thing. i just went and checked my parts bike and i couldnt move the lever on the clutch cover without a wrench on it and that is how mine used to feel..
on mine i can move the lever with one finger... the CLUTCH LIFTER PIN is engaged on the cover but you can tell that there is no pressure on the pin from the clutch plates...????
Old Mar 16, 2008 | 08:55 AM
stynkmonkey's Avatar
Did you forget to put the springs in?
Old Mar 16, 2008 | 10:20 AM
bindelsf2's Avatar
no the springs are in.. i am going to tear it down today and check everything out again.. i have had the clutch out 3 other times and have never had this problem so i have no clue...
Old Mar 16, 2008 | 05:31 PM
bindelsf2's Avatar
i figured it out, the center locknut was torqued but wasnt on all the way i impacted it on and torqued it to 98 ft/lbs and everything is wonderful in the world of the clutch again...thanks for the help though!
idrivea3
May 9, 2010 12:03 AM
02f4irider
Mar 6, 2009 07:50 PM
lakaiguy
Nov 8, 2008 10:54 AM
SNOWMAN
Feb 6, 2008 03:26 PM
Stray Cat
May 1, 2007 02:21 PM
