clutch problem please help!!!!
Old 05-26-2006, 09:17 PM
lowrinlife's Avatar
Default clutch problem please help!!!!
my clutch is grabbing nice and everything, no sign of wearing, so iam in 1st gear then i pull clutch in to shift into 2nd and the clutch cable goes dead.. i inspected the cluth cable and its not broke nor streched...the little black thing that turns on the clutch cover is very easy to spin. now, is a spring broken inside of my clutch? the litle black thing on the cover has not alot of tension on it. thank you!
Old 05-29-2006, 05:13 AM
Default RE: clutch problem please help!!!!
I would put this in general tech it might get more attention from some of the techs. Sorry I could not be more help!
Old 07-30-2006, 02:18 PM
hey im havin the same problem with my clutch, took off the clutch cover and theres a little pin thing in the clutch that it hooks onto there. when i go to put the clutch cover back on it pushes that pin thing back into the clutch and it wont hook on and have tension. mine just happened a minute ago it it would be great if somebody knew somthin about this and posted some help - later
redbaron1728
05-05-2012 07:07 PM
mlrtime99
10-10-2007 03:11 PM
smak_blaze
03-30-2007 05:40 PM
lowrinlife
05-27-2006 12:18 PM
lowrinlife
05-26-2006 09:21 PM
Quick Reply: clutch problem please help!!!!
