clutch problem
Old Jun 10, 2023 | 10:23 AM
Daveblade's Avatar
Default CBR900 clutch problem
Originally Posted by gtp900
Ok, so my clutch out of the blue quits working??? Started today went to start bike, and engaged clutch put into gear and the bike started pulling with clutch still engaged. So I rode for a few minuites shifting through gears fine, and stopped and this issue went away. So I let bike cool down and repeated, same problem did not seem to hold at first then worked fine after warm up. So I go to take bike out again and pull in clutch and shift into first and bang it stalls, try again same result??? Is my clutch fried, or did something come loose?
I’ve had this problem for a while and have just fixed it. After replacing the clutch cable (one from eBay) and the complete clutch the problem persisted so presumed naf eBay cable so purchased a venhill cable and still the same. Lots of swearing later it turned out to be the clutch centre nut had worked slightly loose, re torqued to 130nm and bingo absolutely sweet.
mlrtime99
Oct 10, 2007 03:11 PM
smak_blaze
Mar 30, 2007 05:40 PM
lowrinlife
Jul 30, 2006 02:18 PM
lowrinlife
May 27, 2006 12:18 PM
lowrinlife
May 26, 2006 09:21 PM
