clutch lever in Vs. out
Old Jul 21, 2008 | 08:29 PM
archie's Avatar
Default clutch lever in Vs. out
94 CBF 900RR
Recently had the oil changed to synthetic and my mechanic told me that it was a quart low. The oil should be checked with the last thread on the brim of the oil fill and not twisted all the way in and then pulled out. Correct?
Dont know if I am crazy or not but it seems as though when i start the bike it idles with a slight knock but when i pull the clutch lever in it runs smooth as new. Is this right or do i have a problem?!?!?
Also dont know if the battery has anything to do with this, was suppoesed to be a new one but had to charge it again to get the bike started
Old Jul 22, 2008 | 11:16 AM
archie's Avatar
Default RE: clutch lever in Vs. out
bump....
Old Jul 22, 2008 | 08:30 PM
dinez74's Avatar
I really didnt understand the first one.
You are m o s t probably having clutch cover issue.
Either the bike had been stalled for a very long time or your rectifier is out of order.
Old Jan 20, 2009 | 08:59 PM
archie's Avatar
right on the nail, rectifier and stator needed replaced. now the issue with the thumping, clutch pulled in it stops. one person tells me that its some important engine part and get your kicks out of the bike and let it go. i hear this when the clutch is not pulled in. random thump/knocks.
Old Jan 20, 2009 | 10:31 PM
tecatesr330's Avatar
thats a very good question.i know the noise,i have a 96 cbr 900rr and it does the same thing.when you start it you here it and if you pull in the clutch lever it stops.but mine goes away after it warms up.so either its normal or we both have the same problem.if i find out i will let you know.
Old Jan 25, 2009 | 09:55 PM
archie's Avatar
bump it up.....
Old Jan 31, 2009 | 08:06 AM
scutfargas's Avatar
December 2011 ROTM
Mine does the same thing. Although mine is more on the lines of a slight rattle and not a thump. It probably has something to do with lack of tension on the clutch when the tranny is in neutral. When in gear and when the clutch is pulled in, tension is on the clutch and everything is tight....at least that is what I always thought.
Old Jan 31, 2009 | 09:49 AM
chainstretcher's Avatar
Admin Emeritus & MVN
All wet clutches growl when you let off the clutch in neutral. It's just the plates rubbing a bit as things tighten. If you are hearing a thump then that may require attention. Possibly a deformed steel or clutch basket bolt not tight enough.
Old Feb 3, 2009 | 09:06 PM
archie's Avatar
im sorry, more of a rattle than a thump. does this need attention or is this ok to put on the back burner?
Old Feb 3, 2009 | 09:49 PM
scutfargas's Avatar
December 2011 ROTM
Sounds normal to me. Chainstretcher gave a good explanation of how clutches make noise. I would put it on the back burner.
adams_CBR600f2
Jun 25, 2009 02:46 PM
