choke problem
Old Jun 24, 2008 | 10:53 PM
DunnRR's Avatar
Default choke problem
94 900 choke does not work. I replaced the cable and everything seems to be moving freely on the outside. any suggestions?
Old Jun 25, 2008 | 07:18 AM
gxsretr's Avatar
Default RE: choke problem
Hey wish I could help! my choke works but I'm not sure if its functioning properly. I pull out the choke leverfor a cold start but as soon as the engine starts the choke lever automatically lowers itself. The engine continues to run but at a much lower idle. I don't know much about chokes but I would trace the choke cable back to the engine and make surethat everything is connected right and go from there. Let me know if you find out what the problem is.
Old Jun 25, 2008 | 11:01 AM
NinetySeven900RR's Avatar
GXSRETR my 900 does the same exact thing ... Everything seems to be working fine tho ... It def is something I want to fix ... You guys let me know if you figure out the problem.
Old Jun 25, 2008 | 05:45 PM
Jeff1980's Avatar
For the guys that have the self lowering choke.....There is a 17mm nut located directly below the your choke ****..... snug that up and your problem should be solved.
Old Jun 25, 2008 | 09:19 PM
dinez74's Avatar
Most of us here I believe facing the self lowering choke too. Mine too. As long the choke serve the purpose I think its not a problem. Its kinda helpful too if the choke return itself so no issue on running the bike with the choke on in case you forget.
Old Jul 9, 2008 | 11:37 PM
gxsretr's Avatar
Hey Thanks Jeff I'll look into that, but Dinez74 maybe right on the money cause I wouldn't want to forget its still choked while riding.
Old Jul 10, 2008 | 08:55 AM
Jeff1980's Avatar
LOL, Trust me, if you forget your choke is closed, your bike will remind you in the form of stalling, running like $h@t...etc
Old Jul 13, 2008 | 10:12 PM
99cbr900rrnewbie's Avatar
my damn bike had the same prob. i came on here and asked the same question. And like already said just pull the choke **** up and lift the little rubber boot, underneath that is a tightening nut, just give it a snug and your all set. It will literally take you about 6.8 seconds start to finish.
Old Jul 14, 2008 | 02:44 AM
dinez74's Avatar
ORIGINAL: 99cbr900rrnewbie
Man, that is fast!! You must concentrate in foreplay too....
MeatHelmet1981
Mar 20, 2013 07:34 AM
destindiver1980
Sep 22, 2009 02:15 PM
brveagle
May 6, 2008 10:51 PM
99cbr900rrnewbie
Apr 18, 2008 09:47 PM
desperado
Aug 27, 2007 04:39 PM
