Centrifugal Clutch
Old Aug 29, 2011 | 07:01 PM
estate4life's Avatar
February 2012 ROTM
Default Centrifugal Clutch
Dear All, can anyone define centrifugal clutch type? I've purchase pro Honda HP4M racing oil with moly...but oil is NOT recommended for centrifugal or automatic clutch. I have a 94 cbr900. Does anyone know what clutch type is it?
Old Sep 2, 2011 | 08:45 AM
dbbitt's Avatar
you dont have that kid of clutch
Old Sep 2, 2011 | 10:58 AM
herbcbr1000f's Avatar
A centrifugal clutch is a clutch that uses centrifugal forces to connect two concentric shafts, with the driving shaft nested inside the driven shaft.
The input of the clutch is connected to the engine crankchaft while the output may drive a shaft, chain, or belt. As engine revolutions per minute increase, weighted arms in the clutch swing outward and force the clutch to engage. The most common types have friction pads or shoes radially mounted that engage the inside of the rim of a housing. On the center shaft there are an assorted number of extension springs, which connect to a clutch shoe. When the center shaft spins fast enough, the springs extend causing the clutch shoes to engage the friction face. It can be compared to a drum brake in reverse. This type can be found on most home built karts, lawn and garden equipment, fuel-powered model cars and low power chainsaws. Another type used in racing karts has friction and clutch disks stacked together like a motorcycle clutch. The weighted arms force these disks together and engage the clutch.
When the engine reaches a certain speed, the clutch activates, working somewhat like a continuously variable transmission . As the load increases, the speed drops, disengaging the clutch, letting the speed rise again and reengaging the clutch. If tuned properly, the clutch will tend to keep the speed at or near the torque peak of the engine. This results in a fair bit of waste heat, but over a broad range of speeds it is much more useful than a direct drive in many applications.
Centrifugal clutches are often used in mopeds, underbones, lawnmowers, go-karts, chainsaws, and mini bikes to keep the internal combustion engine from stalling when the output shaft is slowed or stopped abruptly disengage loads when starting and idling.
hope this helps gotta love wikiopedia
http://en.wikipedia.org/wiki/Centrifugal_clutch
Old Sep 2, 2011 | 12:28 PM
February 2012 ROTM
Tks herbcbr1000f...great info. I've been digging into this topic and found below 2 oil test report from Sportsrider. Part 1 & 2.
http://m.sportrider.com/tech/146_0308_oil/index.html
http://m.sportrider.com/tech/146_0310_oil/index.html
Apparently, most sportsbikes uses slippers clutch. Which meant to slip when rear tire speed differs from engine speed. Avoid locking of rear brake.
The Sportriders report clearly states, Moly do not cause clutch to slip....and NO, synthetic oil don't either.
Old Sep 2, 2011 | 12:30 PM
February 2012 ROTM
Avoid locking of rear tire I meant...fat fingers LOL...
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
