CBR900 92 Petcock leak repair or vacuum conversion?
Old Mar 12, 2022 | 05:07 PM
BarryT's Avatar
Default CBR900 92 Petcock leak repair or vacuum conversion?
Hi all
Am in the process of restoring a '92 Blade and it's nearly complete. Found a stinger in the tail though when I fitted the tank and the petcock leaked on the seam of the riveted plate.😣
so, 3 choices.......drill the rivets and see if I can repair it, buy a new one (VERY expensive!) or try to convert the bike to a later model vacuum petcock.
I'll have a go at the repair as it's useless as it is anyway but failing that, has anyone converted to a vacuum type? I was wondering if I could utilise the carb balance vacuum from No1 carb to connect to and operate the petcock vacuum from that?
Anyone who's done it/tried it out there who could offer any advice?
Couple of pics attached of my current junk petcock........
Old Mar 15, 2022 | 02:17 AM
BarryT's Avatar
Originally Posted by BarryT
Hi all
Anyone?
Old Mar 16, 2022 | 10:49 AM
Whilst not exactly the same might this work?
https://www.aliexpress.com/item/3297...rch-mainSearch
Off a slightly earlier cbr600, might have to extend the fuel line a little but looks close and not vacuum fed.
Otherwise looks like drilling is the next option.
Old Mar 20, 2022 | 01:39 AM
BarryT's Avatar
Thanks, but I wouldn't use Chinese parts on any of my bikes. It would be OEM if I'd needed one.
Problem Is now fixed
Old Mar 20, 2022 | 03:52 AM
Ni worries, great that you have sorted it.
What did you do in the end.?
Old Mar 20, 2022 | 05:18 PM
BarryT's Avatar
Drilled the rivets and tapped the holes, eased out the old oddly shaped O ring and reconditioned and re plumped it in warm olive oil.
Refitted it and helped it out by seating it in a thin smear of Hylomar Blue.
Screwed it together and it seals perfectly.
Job done!
Old Mar 21, 2022 | 06:41 AM
Excellent, good job
underground-mpyre
Nov 9, 2019 09:37 PM
JLAvila
Jun 8, 2013 02:34 AM
Ls1Mx5
F2 Tech
Dec 31, 2012 01:09 PM
C Average
F2 Tech
Apr 25, 2010 07:44 PM
Browntowns20s
May 4, 2009 06:27 PM
