Cbr 918 rattling noise
Old May 25, 2022 | 05:42 PM
Topmechanic84's Avatar
Default Engine noise
How does one remove the selectors without removing the engine mate..whats the procrdure drain oil remove clutch cover and clutch basket then what
Old May 25, 2022 | 07:16 PM
chobes's Avatar
I followed the steps here, was able to remove the shift forks out the bottom of the engine...
https://cbrforum.com/forum/how-103/c...cement-151699/
I don't know much about transmissions, might want to check with someone who really knows transmissions why it's hard to get into 3rd. I'm interested to see what you find regarding the noise, as my 919 is rattling also. I posted a video there, does yours sound like that at all?
Old Jun 24, 2022 | 01:25 PM
Mark9's Avatar
Another thought would be pre ignition, I turned my pilot screws down to 2 turns out (should be 3 turns out on the RRV), clatter, clatter, clatter every time I accelerated, turned back out to 3, nice and quiet 🙂
Old Jun 24, 2022 | 03:15 PM
chobes's Avatar
Originally Posted by Topmechanic84
Thanks mate ive allready replaced cam chain tensioner with a brand new genuine honda one and its still the same iam wondering is it the clutch basket springs worn as when i out hand over exhaust there s no noise from engine
Have you replaced the actual cam chain tensioner, or the tensioner lifter assembly?
Part #4 is the cam chain tensioner, part #5 is the tensioner lifter assembly. Part #6 is cam chain guide b, and part #7 is cam chain guide a. If the actual cam chain tensioner is bad, installing what is incorrectly referred to as a "manual cam chain tensioner" (lifter assembly) won't fix the problem, but will stress/stretch the chain as you crank it down to try and quiet the noise. Check the cam chain guides also.
Darren Smith
May 24, 2022 04:20 PM
Topmechanic84
Mar 6, 2022 03:21 AM
DBone
Nov 30, 2008 03:08 PM
koelzer18
Jul 20, 2007 06:31 PM
corona96
Apr 1, 2007 02:14 AM
