ignoring the cctl noise
Old Apr 10, 2006 | 12:42 PM
koelzer18's Avatar
Default ignoring the cctl noise
do you guys think its bad to ignore the cctl noise. i mean if it dont care about the noise will it in turn hurt the gears inside the engine?
[IMG]local://upfiles/4366/FD1C239EE1E34D349B3683FA5FF813CD.jpg[/IMG]
Old Apr 10, 2006 | 03:55 PM
snobrdrdan's Avatar
Default RE: ignoring the cctl noise
It comes in contact only with the Cam Chain
There is no way it'll "hurt the gears inside the engine"
Old Apr 10, 2006 | 05:33 PM
plasteredbassist's Avatar
ok it wont hurt the gears in the engine but will it damage anything? from what ive been reading even after replacing the piece it will again make the same noise after a while if this is just something to get used to no prob i just want to make sure no long term damage will be done to the bike in any way?
Old Apr 10, 2006 | 05:51 PM
Tahoe SC's Avatar
depends...
the noise is the pin in the cctl rattling...but contact with the cam chain is still good and there's still tension there.
however, if the noise is because the cctl is no longer putting tension on the cam chain then the cam chain can (not saying it will but can) jump a tooth.
what to do? get another cctl, mod the old one, or get an APE like many people.
Old Apr 10, 2006 | 06:25 PM
ORIGINAL: Tahoe SC
depends...
hmm so im guessing the only way to tell what the noise specifically is, is to open it up and see has anyone heard of a total failure which causes the engine damage or most of the time is it just the pin making the noise?
Old Apr 10, 2006 | 07:53 PM
will_f3's Avatar
I've read somewhere that the noise really isn't anything to worry about. It is just part of the F4i character. And to think, mags and people say that Honda's don't have a personality
Old Apr 10, 2006 | 09:49 PM
Tahoe SC's Avatar
only bike that i know of where the cctl actually failed and the cam chain skipped, leading to all types of issues was on an RC-51.
the other case, the cctl was defective and the bike ate it hard after like 50 miles!!! the dealer told the dude it was his cctl...but at 50 miles...and then offered to put in an APE tensioner. due to the low mileage, i think something else was going on that they didn't share.
if you ever get into the engine, you'll see that the cam chain is fairly tight even without the cctl. as far as the noise, it could be the cctl pin vibrating back and forth (right to left) in the shaft and not in and out (which would mean no tension at times). more often than not it's this and not due to the lack of tension. but the only way to know is to do the cctl mod.
Old Apr 10, 2006 | 10:12 PM
very cool thanx for the info i was just lookin for some piece of ,ind that my bikes not gonna seize up or explode underneath me haha
Old Apr 10, 2006 | 10:38 PM
Tahoe SC's Avatar
you gots an 02...how many miles mang?
i swapped first out at 22K...and another one at...28K...but only because someone gave it to me for real cheap.
i have 38K in this third one...first one wasn't even bad...second one was worse than the first but still not bad...this third one isn't bad either...
Old Apr 11, 2006 | 10:16 AM
koelzer18's Avatar
hey tahoe. did you replace it with the ape or stock cctl
