CBR 900RR quit while driving
Old May 1, 2013 | 09:33 AM
Pat_CBR900's Avatar
Default CBR 900RR quit while driving
Hi guys,
I just recently bought myself a CBR 900RR and everything was going great until last night. I was out for a ride and my bike and it had been about 5 minutes since I got on the highway and all of a sudden my bike just shut off...no more throttle..nothing. Lights and all of the electrical was still on but motor just quit on me out of nowhere. I don't know much about mecanics thats why I'm asking the question to you guys. I have a hard time understanding this because I did about 400 miles on the bike on sunday, and another 100 miles on monday with absolutely no problems at all! When I try starting it, it will no longer start, the starter works but it motor wont start.
Anybody had this problem before?
regards
Patrick
Old May 1, 2013 | 10:11 AM
74demon's Avatar
Do you have fuel in it and the petcock to on, or reserve? Sounds stupid, but everyone has done it once.
Old May 1, 2013 | 10:20 AM
Pat_CBR900's Avatar
Its not that stupid, it has happened to me before on my previous bike, but yes there is plenty of fuel in it and the switch is on the ON position...I tried it on the reserve position also to see if it would make a difference...
I see a lot of people talking about a Stator problem with CBR-900RR, would this have caused the bike to quit on me while driving?
regards
Old May 1, 2013 | 10:24 AM
74demon's Avatar
If the stator caused it to not charge and you ran the battery down enough that it died, it wouldn't crank and have dim or no lights. The bike runs off the battery, the stator doesn't affect the starting and running directly.
Old May 1, 2013 | 10:29 AM
Pat_CBR900's Avatar
Crap, ok than I have no idea what it could be! Because the batterie is just fine I tested it and it is perfect!
regards
Old May 1, 2013 | 11:00 AM
74demon's Avatar
Are you missing fuel or spark?
Old May 1, 2013 | 02:39 PM
Doug_'s Avatar
April 2013 ROTM
I know this may also sound stupid, I've done it and not realized what I had done. Did you hit the red kill button?
If not then the first thing I would do after determining the battery is fully charged is to check the fuses. If all fuses are good pull a plug wire and check for spark.
Since you said it just shut off I would tend to say it's an ignition problem. Usually when it runs out if gas it will stumble a few times before it dies.
Old May 1, 2013 | 02:42 PM
Pat_CBR900's Avatar
Ok, I know this may sound really stupid...but How do I check the fuses! I mean I know the fuse box is unter the back seat in the tail of the bike...but I did not manage to take it out or open it!
regards
Pat
Old May 3, 2013 | 03:17 PM
ashylarry's Avatar
So it won't idle at all right? It would probably idle, but poorly if it was the fuel pump.
Try disconnecting the stator and rectifier and see if it starts.
For fuses, you'd have to pull each one and see if its blown. I don't have my manual with me at work or I'd tell you which to look at specifically.
Kuroshio
Dec 1, 2011 02:36 PM
astroturf4
Jan 21, 2008 08:21 PM
mikeyvis
Nov 25, 2006 01:40 AM
mikeyvis
Nov 22, 2006 08:58 AM
