CBR 900RR quit while driving
Hi guys,
I just recently bought myself a CBR 900RR and everything was going great until last night. I was out for a ride and my bike and it had been about 5 minutes since I got on the highway and all of a sudden my bike just shut off...no more throttle..nothing. Lights and all of the electrical was still on but motor just quit on me out of nowhere. I don't know much about mecanics thats why I'm asking the question to you guys. I have a hard time understanding this because I did about 400 miles on the bike on sunday, and another 100 miles on monday with absolutely no problems at all! When I try starting it, it will no longer start, the starter works but it motor wont start. Anybody had this problem before? regards Patrick |
Do you have fuel in it and the petcock to on, or reserve? Sounds stupid, but everyone has done it once.
Originally Posted by 74demon
(Post 1230069)
I see a lot of people talking about a Stator problem with CBR-900RR, would this have caused the bike to quit on me while driving? regards |
If the stator caused it to not charge and you ran the battery down enough that it died, it wouldn't crank and have dim or no lights. The bike runs off the battery, the stator doesn't affect the starting and running directly.
(Post 1230074)
regards |
Are you missing fuel or spark?
I know this may also sound stupid, I've done it and not realized what I had done. Did you hit the red kill button?
If not then the first thing I would do after determining the battery is fully charged is to check the fuses. If all fuses are good pull a plug wire and check for spark. Since you said it just shut off I would tend to say it's an ignition problem. Usually when it runs out if gas it will stumble a few times before it dies. |
Originally Posted by Doug_
(Post 1230111)
If not then the first thing I would do after determining the battery is fully charged is to check the fuses. If all fuses are good pull a plug wire and check for spark. Since you said it just shut off I would tend to say it's an ignition problem. Usually when it runs out if gas it will stumble a few times before it dies. regards Pat |
So it won't idle at all right? It would probably idle, but poorly if it was the fuel pump.
Try disconnecting the stator and rectifier and see if it starts. For fuses, you'd have to pull each one and see if its blown. I don't have my manual with me at work or I'd tell you which to look at specifically. |
