burnt wire
Old Sep 9, 2006 | 10:33 PM
Ray Ray's Avatar
Default burnt wire
I have a 98 cbr 900rr and i have been fighting an elicrical problem........after i ride for like 10 minutes and catch a redlight my bike dies out i thought it was the battery so i bought a new one.......as long as i don't let the rpm's drop it does ok......i started digging aroung and found a discolored wire on the reg/rec green.....pretty sure it's a ground.....reg/rec gets pretty hot any guess would be very helpful thanx
Old Sep 10, 2006 | 01:31 AM
jamswain's Avatar
Default RE: burnt wire
here is a link that will help you out with some pictures. Check the wires comming from the stator there are 3 yellow one. Mke sure thay are not burnt. Then follow the steps in te link.
http://cbrworld.net/forums/permalink...ad.aspx#140473
its a good like from a post from eairler.
Old Sep 12, 2006 | 06:18 AM
maxxheadroom's Avatar
I had the same problem on my 93, it ran fine when I got to a stop light it would start to stall out on me. Got to the point where it would just die, didn't have the same power ect... Replaced my regulator/rectifier and have not had a single problem since!
redzintimidator
How-To: Mechanical
174
Aug 8, 2014 01:07 PM
fbpsb82
Jun 29, 2009 01:30 PM
jinxxy_cat
Mar 27, 2009 10:19 AM
chuckbear
Mar 23, 2009 03:27 PM
Slowrider
Nov 3, 2005 01:41 PM
