Bike Stalls When I Pull Throttle Too Far
Old Sep 12, 2007 | 05:46 PM
bori340's Avatar
Default Bike Stalls When I Pull Throttle Too Far
Hey guys, i have a 93 900 and i havenotice these past months when i have the bikeneutral and i turn the throttleback a littlethe bike revs fine but if i pull back on the throttle too far it will stall. Also when im riding if i do the same and pull the throttle back far sometimes it will hesitate before it takes off.
Could it be that the engine isnt getting enough fuel when the throttle is wide open???
Old Sep 12, 2007 | 09:28 PM
dinez74's Avatar
Default RE: Bike Stalls When I Pull Throttle Too Far
Could be... I had this problem some time ago and the mechanic was having headache to solve the problem. He syncronise the carb, and it works perfectly after that.
Old Sep 12, 2007 | 10:29 PM
bori340's Avatar
Yeah i was thinking it could be either the carbs or a fuel problem, i'll probably take out the carbs and see if everything is good condition.
Old Sep 12, 2007 | 10:47 PM
dinez74's Avatar
good idea
Old Sep 12, 2007 | 10:52 PM
bori340's Avatar
hey dinez when you had that problem would your bike start with the choke on??? because thats what happens with mine. starts without the choke, but doesnt with the choke
Old Sep 13, 2007 | 01:10 AM
dinez74's Avatar
I don't had any problem starting her with or without choke.The mechanic cleaned the plugs and serviced the carburetors again and again. He said the setting in the carbsmust be syncronise to get the perfect tuning. Check your plugs too.
MattSD
Apr 21, 2014 04:02 PM
firstbikeF2
May 18, 2011 07:28 PM
Blue5thgenbb
Mar 19, 2011 07:49 PM
DarkNinja75
Oct 15, 2008 05:22 PM
Cru
Sep 12, 2007 03:26 AM
