battery or stator
battery or stator
if your stator is goin out your bike will have trouble running right? i put a new battery in my bike bout 2 mo ago and all was well untill i sent it to the shop for a new clutch get it back and its dead they said it was goin dead but whatever just wondering about the stator and how the bike will act if its going out?
also when it gets hot and i kill it say to go grab a drink in a store when i come out sometimes it starts with one push of the button but others it takes like 5 min of starting which is how i lost my first battery but y is this i dont understand and it is very frustating sometimes any ideas what it is????
ty guys
kyle
ty guys
kyle
RE: battery or stator
1st you want to know that your battery was fully charged from the get go. To do thIis you need to load test it. If you dont have a voltmeter, take it to Autozone or similar and they'll usually do it for free. It should read more than 10.5 volts with a lod put on it. If not, you have a weak or bad battery. Put it on a trickle charger overnight(8-12 hrs) and recheck it. If the readings are still low, you have a bad batery. Do this and let me know what happens, and from there I'll help you further if you need.
ebay man!!! here is the one i got... $30.50 shipped
http://cgi.ebay.com/ebaymotors/ws/eB...023459459&rd=1
It is best to get an updated regulator. I got a performace regulator with the metal backing and front. this prevents any type of over
heating and also allows more HP.
Here is what I brought 120. Shipped:
http://cgi.ebay.com/ebaymotors/Honda...-900-F2-F3-NEW
Check to see if its your charging system. While the bike is running hook up a voltmeter to the battery. The voltmeter should read around 13 to 14 volts. If the voltage is under that, then its more than likely you charging system. Try this and let me know what happens.
