afterburn problem
Old Aug 2, 2007 | 01:05 PM
yolio's Avatar
Default afterburn problem
hi, i already search for info about this problem but i cant find into 900 subforum, in other models (600rr etc) i see there is a PAIR valve that some members say can be disabled
i look at manual and found that cbr900 california type have a PAIR VALVE and i want know if can be disconnected or check for see if is not working
i see to that mi bike dont have de Sub Air Filter, is attached to air filter i must get it?
thanks for the help i see other say the carbs must be raise in low but i want more info about the PAIR valve on this model
my bike is a cbr 919rr 1996
Old Aug 2, 2007 | 03:07 PM
gixxereater's Avatar
Default RE: afterburn problem
You dont have a PAIR valve on this bike.
Old Aug 2, 2007 | 04:29 PM
yolio's Avatar
this is part of manual, i dont believe this model have a Pair valve but later of see the manual go out to look at bike and yes, is there, as soon as i can will take a pic fo system already mounted on bike
Old Aug 4, 2007 | 08:59 PM
yolio's Avatar
i already disable the secondary air system and afterburn as gone
change the cct for an APE and no more noise, other problem was the bike dont go more of 9k rpm now with new cct can take it to red line without problem
i will post pics the monday
Old Aug 4, 2007 | 09:41 PM
Flamed900RR's Avatar
Hey where and how do I get a copy of that manual!?
Old Aug 6, 2007 | 08:47 AM
yolio's Avatar
here is the pics that probe the cbr919 california model have a PAIR valve, its called "Secondary Air Supply System"
the solution, at least while found something for block the tubes
here u can see the tubes of right side
tubes for piston 1 ans 2
for piston 3 and 4
Old Aug 6, 2007 | 08:49 AM
yolio's Avatar
the manual its uploading, will be ready for dw in couple minutes
Old Aug 6, 2007 | 09:03 AM
yolio's Avatar
done
go here
http://www.movedigital.com/go/yolio
and download manual
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
Brza289
Feb 28, 2009 03:57 PM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
