97 900rr cylinder vacuum pressure
Old Jun 28, 2008 | 04:31 AM
kiai's Avatar
Default 97 900rr cylinder vacuum pressure
for who remeber the vacuum pressure when they synced thier carbs how much was it ? mine sucks at 34cm HG and throughing my synpro out of range so I had to use air guage instead is this normal or ? just tell the pressure you were getting if you know it.
Old Jul 1, 2008 | 08:49 PM
sas1810's Avatar
Default RE: 97 900rr cylinder vacuum pressure
as far as i recall, what ever the pressure reading on carb 3 is, thats what you set the rest to. thats the only 1 that cant be adjusted.
Old Jul 2, 2008 | 12:07 PM
stynkmonkey's Avatar
I just did mine a few days ago. #3 was up there and as I started bringing the others up it started coming down and they all met somewhere a little below what #3 was originally at somewhere in the upper 20's to low 30's although I don't remember where exactly. As I understand it, it's not so much where they are at as long as they are all there together.
Old Jul 7, 2008 | 02:04 PM
kiai's Avatar
so around 34cm hg is not that bad after all, I know the value doesn't count as long they are almost equal but most of the bikes I've had had less pressure than this one so I was wondering if something basically wrong so thought to compare with everyone else tho
my94f2
F2 Tech
Aug 23, 2011 06:49 AM
bmmballer07
Aug 2, 2011 12:21 PM
CBRnoobie
Oct 11, 2010 01:20 PM
LJ Harp
Oct 9, 2010 03:01 PM
