Possible Vacuum leak??
Old Jul 25, 2011 | 08:28 AM
bmmballer07's Avatar
Angry Possible Vacuum leak??
So I am kinda stuck, the bike is idleing at around 2,000 rpms and when you give it gas and then pull in the clutch the bike doesn't slow down. The rpms just stay high like the throttle bodies are staying open but I have check all the throttle cables and it is working properly. The bike also won't slow down when you let go of the gas from the exhaust. It kinda just sticks open so you coast. Any ideas?
Old Jul 31, 2011 | 01:46 PM
highwaypatrol's Avatar
2000 rpm is quite high for an idle speed. Try slowing it down to around 1200-1300rpm using the idle screw down on the left hand side of the bike below the tank. If the idle speed is that high it will increase a lot as the engine get hot. The throttle slides may be sticking, but try lowering the idle speed first to see if that helps then we can go from there.
Old Aug 2, 2011 | 12:21 PM
Can't adjust the idle on an 2007, its controlled by the IACV and ECM
CBRnoobie
Oct 11, 2010 01:20 PM
uhhmoney
Sep 22, 2010 09:28 AM
puma690
Mar 6, 2009 03:01 PM
95Cbr6
Mar 10, 2008 07:36 PM
grwilson6
Jun 25, 2007 01:40 AM
