96 to a 99 conversion
how hard is it to do, and what would i need plastic wise, i know the front and the rear are different, but what about the middle and lower, also how much modification would i need to hook up the front, and would the rear be hard to do
You can bolt the upper and the tail on, but the you need the 98-99 headlight,tailight,and brackets.the mirror stay, and mirror are also different...Basically off the top of my head you need tail section, left/rite/ and back center, plus tail light, also upper,light,mirror stay bracket,mirrors,windscreen,unknow about the actual upper front bracket..The mids from what i was told bolt rite up. remeber the 98-99 has a differnt front end, forks/brakes..I saw in another post you had more problems with the bike, glad to see you kept her, good luck in fixing her up.. I wound up finding a clean 98 for 4500...Hope this helped..
thanks for the advise, now just were to find all this?, ya i was doin a wheelie and ended up landing it to hard and the regulatore whires all fell out and touched so i had to get another regulator,
