93 900 problems
Old Aug 1, 2007 | 02:04 PM
ray3535's Avatar
Default 93 900 problems
I bought a 93 900 rr that was wrecked. All that was wrong with it wasfront plastic and a couple of wires. The bike runs decent when cruising but when your on it pretty hard it seems sluggish. It also backfires a little when you let off and when going down my road out to the highway at low speed it sounds like its missing. PLEASE HELP GIVE ME SOME IDEAS as I have tried Dyna Ign and just about everything under the sun.
Old Aug 1, 2007 | 02:08 PM
JSTATL's Avatar
Default RE: 93 900 problems
change the plugs because they probably are fouled or have oil on them from the wreck
depending on how long it sat up you may have to change the fuel filter also, also check to bike to make sure that it does not have any exhaust leaks. If all of this fails get the bike rejetted
Old Aug 1, 2007 | 03:45 PM
ray3535's Avatar
I just pulled the carbs off and found a small piece of foam stuck underneath the diafram(dont know how to spell it) next to the needle on #2. could this be some of the problem? plugs are new and has d+d pipe and header no leaks
Old Aug 1, 2007 | 03:50 PM
JSTATL's Avatar
sounds like you found the problem
m21oliver
Oct 1, 2018 10:52 AM
clintthec
Jul 27, 2011 06:04 PM
honda23
Jun 28, 2011 12:24 PM
cr cbr
Nov 28, 2006 04:36 PM
