Cbr650f de-restriction with ecu flash & tune
Old Aug 31, 2019 | 11:48 PM
CBR650F's Avatar
New Member
Default Cbr650f de-restriction with ecu flash & tune
Hi Guys,
I'm located in Australia and recently got my CBR650F de-restricted with a ECU flash and tune.
They also removed the 02 sensor and the restriction from the velocity stacks.
I got a full Yoshi system and DNA air filter installed as well.
Now, I love the power it's making (nearly 80hp) but have noticed something that's bothering me.
No matter what rpm I fully twist the throttle at, the response is very jerky like it has to think about it.
This doesn't happen if I slowly twist the throttle however, only if it's suddenly snapped back.
I told the dyno shop where I got it done and he seems uninterested and said the process comes at a cost.
Does this sound right to you? Should I take it to another dyno shop for a second opinion?
Does anyone know why this could be happening?
Thank you in advance.
Benyamin.
Old Nov 1, 2019 | 05:38 PM
baugustine's Avatar
Why did they remove the O2 sensor? That is a crucial input to the PCM for fuel control. When you crank the throttle the throttle plates open and the motor takes a huge gulp of incoming air, making the mixture very lean. The PCM has to quickly respond with fuel/timing. What is the tuner using for fuel control other than MAP, TPS, IAT, ECT?
F2CMaDMaXX
Dec 22, 2016 11:56 PM
hebbo
Mar 4, 2012 12:16 PM
gotama
Dec 11, 2011 12:36 PM
rcmadawala
Jul 8, 2010 05:48 PM
arkas
Dec 2, 2005 04:32 PM
