wont start?? help...
Old 06-18-2007, 03:31 AM
four.six's Avatar
Default RE: wont start?? help...
k, i will try that. let you guys know in the mornin. thanks
Old 06-20-2007, 04:00 PM
four.six's Avatar
charged NEW battery for 24 hours and reads 12.04.. does that mean its a bad battery?? still wont start and still clicks. HELP!!!
-i bought a brand new schumacher slow charge 1.5amp charger at walmart for this. could the charger be bad?
-havnt got to ride my bike for WEEKS now...
Old 06-20-2007, 04:21 PM
meanstrk's Avatar
Should read 12.5or so charged without the key on. The real test is to see what itdrops to when trying the start the bike though. If it drops below 11 volts under load, it's toast.
Just out of curiosity, have you tried to jump it from avehicle with a known good battery and some jumper cables? If not, give it a shot but make sure the vehicle's motor is not running.
Old 06-20-2007, 04:44 PM
i might have the sameproblem it reads 12.51v but it does not have enough power to start the bike? not to steal the thread but it might save me $$ like 110 for a new one.
Old 06-20-2007, 07:34 PM
Before I say anything... I just got my first bike which happens to be a 2004 CBR600RR. So when I give advice just keep that in mind because by no means am I as experienced as most people here.
However, I did have this EXACT same problem. Turn the key, sounds like it's charged and ready to roll... hit the ignition and nothing but a rapid clicking under the seat. At first I thought it was a loose connection or fuse. That was all fine. I read up on how to charge the battery by using your car battery and took that step. *Note that as doncollins said a 1.5 amp is recommended* The Charge held for about an hour. Charged again.... Less than an hour. Everyone I talked to said it was the battery so after discovering that the 600rr has one of the most exspensive batteries I wasn't too thrilled to buy one. Picked one up at Interstate Batteries for about $150.00 including tax. Now the clicking's completely gone and it holds it's charge.
I hope you don't HAVE to buy one but as a last resort you may have to. Also, according to interstate the average sportbike battery lifetime is between 13-18 months depending on how often you use it. I hope this helped.
Old 06-20-2007, 09:22 PM
Push start the darn thing that will let you know if it is the battery or not...
Old 06-20-2007, 10:20 PM
four.six's Avatar
i have pushed started it plenty of times... lol, it sux!
i will try jumping it with a car. thats a good idea. i didnt know if that would work or not. thanks!
Old 06-20-2007, 11:04 PM
meanstrk's Avatar
Oh man. You never said you could push start it.......
Battery is toast most likely, but get it started and see what the charging voltage is. So long as it is charging at 14volts or so while running, the charging system is good.
supermover25
03-15-2019 08:14 PM
C Jacob W
07-29-2013 11:03 AM
CTcbr929
07-31-2009 12:25 PM
tagger609
06-27-2008 02:09 PM
mishab
09-07-2007 01:00 AM
Quick Reply: wont start?? help...
