Turn signal switch issues.
Old Jan 31, 2023 | 05:52 PM
BurninGreens's Avatar
Default Turn signal switch issues.
Got a 2005 that is having turn signal issues. I cleaned the connections on the toggle slide, seemed to help for a day before issues continued. When switching between left and right, the indicator light on the instrument panel will light up for a second before returning blank. Thing is the signal is still getting to my integrated helmet light will display the correct signal direction. I purchased a new OEM switch but sill having same issues. What’s next to start look for?
Old Jan 31, 2023 | 07:52 PM
dannoxyz's Avatar
Show wiring-diagram how you have helmet-light is connected to bike.
Switch is just red-herring, and now you've got 2 different mods to troubleshoot.
Put original switch back in so we can remove new switch as possible problem
Then disconnect helmet light.
Does winkers work now?
Do you have multimeter and know how to use it to measure voltage, resistance and current?
This is 5-minute fix with mutlimeter.
CARELESS
Feb 11, 2017 04:30 PM
HondArai
Mar 24, 2014 05:09 PM
Meanf3i
Aug 15, 2011 10:01 PM
sevenhillsbilly
Aug 28, 2009 02:36 PM
mr_santini
Mar 29, 2009 04:06 PM
